Date/Time: Wed, 25 Nov 2026 22:20:47 +0000
SC is creating a phantom oder that causes the DOM P&L to be incorrect
View Count: 579
| [2025-04-14 20:36:26] |
| User443772 - Posts: 14 |
I'm connected to R trader (Rithmic Dirrect - DTC Trading) with Teton. When I place an order on the SC DOM it is correctly handled and recognized by R trader. When I exit the trade the result (entry, exit, P&L) is correct in R trader, but SC creates a random position (order) and closes it and then calculates the P&L incorrectly. (eg. I have an order for 2 contracts at 10AM and I close the order for 2 contracts at 1015, but SC only closes one of the 2 and picks up a random contract from earlier that never existed.) Everything in R trader is correct regarding the quantity, entry, exit and P&L so Teton and SC are communicating correctly. According to the SC DOM there were no open orders; I have even done a flatten and close all prior to beginning trading for the day. This does not happen in sim, only when connected by Teton to R Trader. |
| [2025-04-15 05:45:40] |
| Sierra_Chart Engineering - Posts: 25484 |
We are not exactly sure where you are looking at this in Sierra Chart. Make sure you are not using the order fill calculated position: Trading Information Windows: Disabling Order Fill Calculated Trade Position If you are looking at this in the Trade Activity Log, then refer to: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List And: Trade Activity Log: Open Quantity Field Calculation Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-15 05:46:00
| [2025-04-15 22:24:36] |
You can close this. I had to delete the data, and make the suggested changes in the beginning date/time. It was not an elegant solution, but it was just too time intensive and the trade data was available elsewhere. Thanks. |
