Date/Time: Wed, 25 Nov 2026 22:20:43 +0000
Connect to AMP Futures
View Count: 957
| [2025-04-14 18:52:15] |
| User344478 - Posts: 165 |
Am I enabled connect AMP Futures using your software?
| [2025-04-15 06:08:43] |
| Sierra_Chart Engineering - Posts: 25484 |
Yes you are on Service Package 10. We recommend using Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-15 06:09:08
| [2025-04-15 15:03:59] |
I would like use CQG. please help me with live connection to CQG Datafeed
| [2025-04-15 21:01:55] |
Follow the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
