Date/Time: Wed, 25 Nov 2026 22:20:50 +0000
Scale Range Setting Visual Display
View Count: 633
| [2025-04-11 10:53:17] |
| Mercrastius - Posts: 73 |
I use the Constant Range scale setting (manual mode, interactive scale move checked) on my chart, and typically set it once and forget it. However the recent market volatility has required me to adjust this setting frequently. Without opening the scale settings window, is there a way to display the current constant range value somewhere visually on the chart? Maybe at the top/bottom of the values scale column, or possibly similar to the text display for study functionality? See attached image. Thanks |
| [2025-04-11 16:41:28] |
| Sierra_Chart Engineering - Posts: 25484 |
There is no built-in support for this but a custom study could be developed to do this.: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-16 07:35:12
