Date/Time: Wed, 25 Nov 2026 22:25:59 +0000
Chartbook file not compatible.
View Count: 735
| [2025-04-07 14:43:59] |
| xnecax - Posts: 3 |
Can you please update this chartbook files to the current version? Thank you for your time! |
| Attachment Deleted. |
| [2025-04-07 18:02:53] |
Refer to the following for how to do this: Chartbooks (Workspaces): Opening Older Chartbooks Unless this happens to be a very old chartbook that you have not used for a few years, then the chances are that this file is corrupted. If it is, then you would need to access a backup copy. Refer to the following: Chartbooks (Workspaces): Accessing a Backup Chartbook File Also, the account you have posted from is expired. We typically do not give any support for expired accounts, but this was a straightforward enough question. If you need further help you need to login with your active account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
