Date/Time: Wed, 25 Nov 2026 22:26:13 +0000
How to instantly re-center the DOM via constant range scale
View Count: 822
[2025-04-04 11:02:33]
c_currency - Posts: 11
When I set the Dom to re-center using the constant range scale mode - re-centering when the last price exceeds a certain number of ticks - it always scrolls up or down slowly when re-centering, instead of instantly which makes it difficult to read the order flow. How do I make it re-center instantly, similar to how it does when “re-centre on shart scroll” is activated.
Many thanks
[2025-04-04 15:20:10]
Set the "Adjust Interval" to 1. Refer to the following:
Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center When The Last Price Exceeds A Certain Number Of Ticks From The Center
[2025-04-07 18:42:33]
Thank you
