Date/Time: Wed, 25 Nov 2026 22:26:02 +0000
Hot key to move Stop to Current Price +/- 15 ticks
View Count: 856
[2025-04-03 16:34:04]
User643426 - Posts: 144
I'm looking to create a Hot Key that will Move the Stop to Price +/- 15 ticks. I see the "Move Attached Stops to Price" Hot Key but that will exit the trade. I want to trail price manually as fast as possible. I do this manually with the Stop Tick Up/Down Hot Key but it takes too long when the NQ can move 30 points in 1-2 seconds.
[2025-04-03 16:49:51]
This would require a custom study. Refer to the following:
Automated Trading From an Advanced Custom Study: Modifying an Order
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2025-04-04 21:48:15]
Okay thank you. I received notification that the Server Side limit loss function is being disabled and it is no longer offered by my broker. I'm wondering if you can please keep in place or if there is another solution.
[2025-04-06 14:51:00]
ForgivingComputers.com - Posts: 1256
Another Solution: https://forgivingcomputers.com/advanced-risk-management-tool-for-sierra-chart/
