Date/Time: Tue, 17 Nov 2026 18:08:51 +0000
Connect to AMP
View Count: 869
| [2025-03-08 22:12:28] |
| Futurosbrais - Posts: 5 |
Good morning, I founded a AMP account and I need to connect market data to my sierra chart account. Wich is the next step? My AMP account number is *. Thank you. Date Time Of Last Edit: 2025-03-09 18:54:26
| [2025-03-09 10:54:56] |
| User135243 - Posts: 334 |
not if you have an AMP-account is important, important is with which data this account is connected??
| [2025-03-10 15:40:56] |
| John - SC Support - Posts: 48555 |
You do not have any data setup with us. What order routing service are you using with AMP?
| [2025-03-10 16:34:10] |
I want to connect Denali Teton to AMP account and trade with sierra. But I don“t know how to do it. Could please explain me that? Thank you very much.
| [2025-03-10 17:34:14] |
Follow the instructions at the following link (make sure you follow the sub-instructions at Step #5 to setup the data as well): Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-14 13:53:00] |
Hi, I've already connected AMP to Sierra. I think I've already paid for the data. Could you confirm this? If so, I'm still getting delayed in Sierra. Could you please connect it? Thank you. |
| [2025-04-14 15:16:51] |
| Sierra_Chart Engineering - Posts: 25432 |
You need to activate the exchanges that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-14 15:32:40] |
I've already completed those steps and am connected to Denali via Teton. However, my data is still delayed.
| [2025-04-15 06:34:20] |
You still do not have any exchanges active here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
