Date/Time: Wed, 25 Nov 2026 16:39:06 +0000
Sim orders in replay appear only after switching show order fills on/off
View Count: 750
[2025-02-24 15:12:30]
User707785 - Posts: 10
*** Probably solved ***
The reason seems to be the settings under Chart Settings - Data Limiting. If I replay 2024-01-04 and have set "Number of Days to Load to 600, it works. If I set it to "Use Date Range" and set "From" to 2024-01-02 and "To" to 2024-01-31, it doesn't work. Probably because the contract (NQH25.CME) didn't exist back then?
When I replay a chart, my position and my order fills are only shown after I disable and then re-enable 'Show Order Fills'. I have to do this for every order after the execution time for the order was reached.
I have deleted all files in my SavedTradeActivity folder, but that didn't help.
The strange thing is that it works on a fresh chart that I add tt the chartbook. On this fresh chart the orders are shown automatically at the right time. I have tried to duplicate my original chart and deleted all my studies, but still wasn't able to get the same result as on a fresh chart. I have set the Chart Settings Order Fills Start Date correctly to a time before my trades.
Any advice would be very much appreciated.
Date Time Of Last Edit: 2025-02-24 21:31:23
[2025-07-11 17:20:36]
Sierra_Chart Engineering - Posts: 25481
Let us know if you need more help.
