Date/Time: Sun, 11 Oct 2026 10:14:57 +0000
historical data for CQG connection
View Count: 668
| [2025-02-20 21:59:03] |
| User368741 - Posts: 106 |
Hi I am planning to start live trading through CQG and I wanted to know how can I obtain the historical data for following exchanges ICE US , ICE EU, Euronext , SGC/SIMEX, DCE and ZCE . For CME and EUREX denali data feed provides the data . for the other exchanges do you have another data feed option ?
| [2025-02-20 22:02:23] |
I would also like the same information for following exchanges too : BMF , Bursa Malaysia and ASX
| [2025-02-21 00:07:24] |
| John - SC Support - Posts: 48169 |
You would have to get that data from CQG if you are wanting to use it in the charts from which you will be trading. If you are not trading from those charts, but just want the historical data to review, or work with separately, then check with DTN to see if they have what you need. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-02-21 08:12:07] |
Is it possible to do this in the following way by setting two instances of sierra chart? 1. Set Up the Live Data Instance (CQG) 2. Set Up the Historical Data Instance (DTN IQFeed) 3. Sharing or Integrating Data Between Instances to combine historical data from the IQFeed instance with live trading charts from the CQG instance, which approach would be better ?: Using the DTC Server: Sierra Chart supports the Data and Trading Connectivity (DTC) protocol. You can designate one instance (for example, the DTN IQFeed instance) as a DTC server and have the other instance connect as a client. To set this up, go to Global Settings → DTC Server Settings in the instance you want to act as the server, configure it, and then connect from the other instance via Global Settings → DTC Client Settings. This enables real‑time sharing of historical (or even live, if needed) data between instances. Manual Export/Import: Alternatively, you can export historical data (e.g., via CSV export) from the DTN IQFeed instance and then import it into charts in your CQG instance. This method is less dynamic but can be useful for backtesting. |
| [2025-02-21 14:05:18] |
| Sierra_Chart Engineering - Posts: 25128 |
No this is not possible. All of this is kind of sharing is disabled due to exchange rules. Do not spend any time on this. It will not work. You could do this, but it is not something we will help with: Alternatively, you can export historical data (e.g., via CSV export) from the DTN IQFeed instance and then import it into charts in your CQG instance. This method is less dynamic but can be useful for backtesting.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-21 14:06:03
