Date/Time: Thu, 19 Nov 2026 13:09:25 +0000
TPO and Volume profile display
View Count: 2972
| [2025-02-16 15:48:58] |
| User937068 - Posts: 45 |
Hi I've been playing around but i am unable to find a way to make TPO and Volume profile to look like in the Untitled screenshot. The best i can get is to have Volume Profile matching the Ticks per Volume bar of the TPO. If i have my TPO Letter/Block Price increments in Ticks set to 40 then Volume Profile Ticks per Volume is automatically set to 40. Like in Untitles2 screenshot. Is there a way to overcome this? For my decisions i need to see the low volume nodes and volume gaps with more accuracy and having it next to TPO will save some screen space. |
| [2025-02-17 16:32:01] |
| John - SC Support - Posts: 48583 |
When you have a Volume by Price study that is set to be based on a TPO study ("Volume Graph Period Type" set to "Based on TPO Chart") then the "Ticks per Volume Bar" are going to be set by the TPO Chart, there is no way to change this. The only way to have something like what you are wanting is to have a single profile that has the Input for "Set as Independent Volume Profile for TPO Chart" set to "Yes". But in this case the Volume Profile will not be aligned next to the TPO. Refer to the following: Volume By Price Study: Set as Independent Volume Profile for TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-02-17 18:32:48] |
Hi John This is still quite good if it's being used for current profile that was the main goal. Thanks a lot. |
