Date/Time: Thu, 19 Nov 2026 12:33:33 +0000
Spreadsheet for Trading - Reorder column I/J
View Count: 470
| [2025-01-27 13:53:16] |
| User374751 - Posts: 44 |
Support, Does the system provide any method to reorder the cells in column I, and corresponding cells in column J? I ask because there are cells that I constantly monitor that would best placed near the top of the column, in the visible part of my screen. I have a large monitor but I cannot see all of the cells at one time that I constantly monitor. I know that I can reference particular cells of interest in another column, however, this creates additional CPU load, than if I could move the cells up or down in column I. |
| [2025-01-27 22:42:03] |
| John - SC Support - Posts: 48583 |
There is no support for specific ordering of the Column I/J cells. But, there are two setup options for those cells. In the Spreadsheet systems there is an Input "Use Column I and J Values Version 2". Version 2 of these values is a more organized version. You would have to see if it has the particular items you want at the top. Refer to the following: Spreadsheet Study Inputs: Use Column I and J Values Version 2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
