Date/Time: Thu, 19 Nov 2026 12:33:16 +0000
Bar Has Closed Logic - ACSIL
View Count: 921
| [2025-01-27 07:21:12] |
| Balazs - Posts: 13 |
Dear Support, I cant find it in the documentation, but when autoloop is on and I used the "BarHasClosed" function, when the bar closed, does the code only(!) execute the part of the code within this BarHasClosed function, or does the complete code run again (and obviously including now the section of the BarHasClosed as well). This would make a big difference on how I structure my code and put what function where. thanks in advance. |
| [2025-01-27 19:43:37] |
| Sierra_Chart Engineering - Posts: 25441 |
Certainly, the study function is called for the indexes as explained here and executes: Working with ACSIL Arrays and Understanding Looping: Automatic Looping/Iterating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-27 19:44:02
