Date/Time: Thu, 19 Nov 2026 12:33:14 +0000
Feature Request: Lock/Unlock All Drawings Toggle Switch
View Count: 812
| [2025-01-26 15:21:10] |
| User456869 - Posts: 6 |
I use the Lock Drawing feature on an individual basis for horizontal lines. Could I ask you to add a feature where, with the click of a button, all drawings are simultaneously locked or unlocked? It would save me (and others) time when charting. Thanks you for considering this request.
| [2025-01-27 21:26:22] |
| John - SC Support - Posts: 48583 |
You can do this from the "Manage Chart Drawings" window. On that window do the following: - Select "Options >> Multiple Selection" (or Select All if you want to select all the drawings) - Select the drawings you want to lock. - Select the "Lock" button at the bottom. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
