Date/Time: Thu, 19 Nov 2026 12:31:15 +0000
Replay charts with same link number issue
View Count: 531
[2025-01-25 16:52:21]
Keysz - Posts: 17
When using SC Replay (with same link number) to start at 09:29:59, the replay automatically begins at 18:00:00 on Standard Replay and will not replay at all on any other mode.
All of my charts have 30 days to load and the date-time is within that parameter (9 Jan).
All of the session times are set to 00:00:00-23:59:59 with the evening session set to 'No.'
My global time zone is NY (-5 EST) and my chart time zones are the same.
Grateful for some assistance as I can't seem to find a fix
[2025-01-27 19:15:41]
Are you using the option for "Use Start Date-Time"? If so, what is the Starting Data and Time that you have entered?
Do you have this issue if you run a replay on just the one chart from which you are trying to start the replay for all linked charts?
