Date/Time: Thu, 19 Nov 2026 12:33:15 +0000
probleme connection
View Count: 569
[2025-01-24 15:37:04]
Utilisateur847389 Utilisateur847 - Posts: 4
bonjour avez des probleme avec la plate forme je n est plus de connection
[2025-01-24 16:11:40]
From Google Translate:
Hello, you have problems with the platform, I no longer have a connection.
We are not having any issues with our servers, so whatever problem you are having is just at your end.
What exactly is the problem?
[2025-01-27 09:52:24]
bonjour mon problème est le suivant ,ca fait trois ans que je suis connecté a la propfirm eanr2trade tous va bien jusqu a il y a deux jours la plate forme ne se connecte plus a rithmic voici le message d erreur : connection error message from service : rithmic direct -dtc logon error receveid from server :permission denied
[2025-01-27 11:52:35]
cgavachart - Posts: 15
Same issue for me on version 2700/51585 of Sierra Chart.
I will try version upgrade
[2025-01-27 22:24:49]
Refer to the following for the "Permission Denied" error from Rithmic:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
