Date/Time: Thu, 19 Nov 2026 12:23:19 +0000
I keep getting this error in my log Did not find FIELD_CODE_BEGIN_RECORD when expected
View Count: 515
| [2025-01-24 06:03:08] |
| User183724 - Posts: 194 |
2025-01-24 00:01:15.241 | Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-04-24_UTC.None.data * thx tim |
| [2025-01-24 15:10:18] |
| John - SC Support - Posts: 48583 |
You can ignore that message, as it is relating to a log that does not have any data in it. If you want to get rid of the message, then you will have to delete the file that is being referenced by exiting from Sierra Chart and then deleting the file through the Operating System. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-24 19:57:36] |
| Sierra_Chart Engineering - Posts: 25441 |
Yes, delete that file.
