Date/Time: Thu, 19 Nov 2026 12:31:17 +0000
Contract Size per Trade not logging when trading from Chart dom
View Count: 551
[2025-01-23 13:01:07]
florianh - Posts: 19
How can I configure Sierra Chart so that the Trade Activity log shows the total position size for the same trade, rather than listing each added order as a separate entry? For example, if I click the buy button 5 times to increase the position size of the sames trade, I want the log to display this as one trade with 5 contracts and the average price, not as 5 separate entries. The goal is to export Trade Activity with correct position size per trade to the journal (I use Tradersync). I know this works fine in other trading platforms.
Date Time Of Last Edit: 2025-01-24 12:43:24
[2025-01-24 23:24:59]
You cannot export data this way. However, the Trades tab of the Trade Activity Log does support combining trades into what is called a flat to flat trade:
Trade Activity Log: Order Fill Matching and Flat to Flat Definition
Date Time Of Last Edit: 2025-01-24 23:25:27
[2025-01-24 23:53:00]
Thank you. I was indeed referring to the Trades Tab where I only see single trades with contract size 1 each.
I do have LIFO activated to suit my trading style, does it mean I must switch to FIFO in order to see the correct flat-to-flat trades in the Trades tab?
[2025-01-27 19:05:41]
It does not matter if you are using LIFO or FIFO for the order fills for the trades tab and setting the option for "Flat to Flat Display for Trades List".
