Date/Time: Sat, 21 Nov 2026 00:42:11 +0000
Request For An Additional Setting Option For the VWAP and VbP Studies
View Count: 2547
[2014-09-14 01:09:02]
ged - Posts: 233
I have several VWAP and VbP studies on my chart. Each VWAP and VbP pair of studies is intended to represent a distinct timeframe, i.e., 1Day; 2Days; 1Week; 2Weeks, 1Month; 2Months; etc.
By way of example, the present setting options result in this difficulty:
The 2Day VWAP and VbP pair end up sharing one day in common with the 1Day VWAP and VbP pair;
The 1Week VWAP and VbP pair end up sharing one week in common with the 1Week VWAP and VbP pair; etc.
If the settings options for the VWAP and VbP studies were amended to include a new option that on each new trading day the 2Day VWAP & VbP will automatically be building its second day, then this pair will never be duplicating the 1Day VWAP and VbP.
Similarly, the 2Week VWAP and VbP could the be set so that they are always completing the 14th day of their 2Week period on each new trading day. Thus, they would never simply duplicate the 1Week VWAP and VbP, but rather would always reflect the full 2Week time period they are intended to represent the values of.
The above requested setting option addition is very practical and I suspect it would be a genuine benefit to a number of users. Thank you for considering this request.
[2014-09-16 11:11:01]
ged - Posts: 233
Not sure what the status of the above request is.
The manner in which I would like to use several VWAP & VbP pairs is consistent with a trading tool referred to as "Market Statistics" in a popular series of threads at the Traders Laboratory Forums several years ago. Those threads continue to attract attention today.
However, unless I can control the period reported by the several VWAP and VbP pairs (as described in my request above), I can't, as a practical matter, properly apply the tool. As an example, today I had so many VWAPS of varying lengths piled directly on top of each other that I simply had to "hide" all of them accept today's VWAP (so that I would be able to see today's VWAP). Consequently, the value of the other time period VWAPS (and VWAP/VbP pairs) is lost to the tool.
I appreciate SC's consideration of adding the requested setting option.
[2014-09-16 16:35:21]
We cannot be expected to give an answer to a feature request especially one that is highly complex.
We will have a quick look at this, and put it down for future reference. Please understand that it could even be potentially more than a year before this even gets reviewed in detail. We try not to take the long but sometimes that happens.
Date Time Of Last Edit: 2014-09-16 16:37:25
[2014-09-21 16:50:55]
We have had some time to look this over.
In the case of the Volume by Price study, this is already supported.
Set the Volume Graph Period Type to One Period At End of Fixed Time Length.
Date Time Of Last Edit: 2014-09-21 16:51:27
[2014-09-21 20:11:09]
ged - Posts: 233
That method works for the VbP, but will not resolve the negative effect of VWAPs building on top of one another on certain days.
Additionally, by selecting One Period At End of Fixed Time Length, then the VbP's from prior periods will not be available for use in analysis (unless a second set of charts is created with only VbPs - to avoid the duplicative problem - and the trader references back and forth between the two chart sets - which is not a practical solution.)
[2014-11-18 12:16:59]
wwwingman - Posts: 185
Hi ged,
I am not sure to fully understand your problem but ... maybe one of my vwaps can help. It is ECIVwapAnchor.
It is a vwap you can anchor at any moment on the chart and it will compute the vwap from that moment until the last bar.
For your need : make 2 ECIVwapAnchor, and anchor them on start of previous day and current day. The first will compute your 2day vwap and the second will compute the current day vwap.
ECIVwapAnchor is part of sierra contributed studies. Anchoring is done with right mouse + AnchorVwap.
W.
[2026-10-05 22:57:16]
ameetmedi - Posts: 52
I didn't find another thread addressing this except this older one. Is there a better way to get a 2Day or 5DAY VWAP? I tried using the Multiple profiles using the VBP study but it ends up being a rolling on. I'm looking to have a 2Day or 5Day that resets every 2 or 5 Days like the option One session reset every day.
Or is there another study I can use to get 2day Vwap
[2026-10-06 15:31:05]
To get what you want, you would need to use the Volume by Price study. You can set "Draw Mode" to "POC, VAH, VAL, VWAP Lines Only" and set the subgraphs for the POC, VAH, and VAL to "Ignore" so you only get the VWAP line.
Then set the following to get a 2 Day VWAP, for example:
- Volume Graph Period Type: One Period at End of Fixed Time Length - Auto-Skip Empty Days
- Time Period Type for 'Fixed Time': Days
- Time Period Length for 'Fixed Time': 2
You may want to set "Minimum Time Period % for Reference Days Back" to "0" in order to ensure you get the previous day information, or it may skip, depending on how much data you have available for that day.
[2026-10-20 17:58:09]
How do I ensure that it's only using the Day session for the 2 days? There is a setting
"Exclude Evening session except for the last day", I assume with this its still using the evening session from 1 day (previous night)?
My setting for Use separate profile for Evening session is marked Yes.
Reason is I find my 2DVWAP to be different from TOS or from TV
I'm using Evening/Full session but wanting to exclude the evening session without the exception of allowing the last day
[2026-10-20 18:38:57]
The Inputs for the VbP related to the Evening Session are only valid for when you have multiple daily profiles.
If you have a chart with the full session (day and evening) and you put on a Volume by Price that is set for 2 days, then you will get the full 2 days of data (day and evening) in that profile.
The only way to get a 2-day profile that does not include the evening sessions is to put that on a chart that does not include the Evening Session.
[2026-10-20 21:54:41]
I see. and there is no other way to get the 2Day VWAP through another study the ignores the Evening sessions?
[2026-10-21 14:26:40]
Sierra Chart is setup so you can overlay most studies from one chart to another. So having a chart that does not have the evening session on it and then adding the Volume by Price study and setting it up as you want, can then be overlaid to your full session chart to display what you want using the "Study/Price Overlay".
You can then hide the RTH only chart so it will not use any resources for display. This does not cost much more, in terms of resources, than having a single study that does what you want directly.
The one thing you will need to do is to set the "Draw Mode" of the Volume by Price study to "POC, VAH, VAL, VWAP Lines Only" in order to actually be able to overlay those lines.
