Date/Time: Fri, 03 May 2024 11:10:49 +0000
Use Date Range versus Date in File
View Count: 1733
[2014-10-03 04:33:05] |
We do not think that that limitation is the problem as long as the data is being downloaded during the evening session hours. Additionally, we get the very same result using your Chartbook and the Sierra Chart Exchange Data Feed which has complete tick data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-07 03:17:33] |
RobertL - Posts: 26 |
Here is my friends chartbook he was so kind so send. He also gets 4059 for the VPOC, but when I use DTN data feed I get what we had 4066 which is not correct as IRT still shows 4058.50 for the current Comp VPOC. If I do have an incorrect setting , would like to know what it is. Thanks |
[2014-10-07 03:28:12] |
We quickly recognize the problem. The chart is set to do back adjustments for the Continuous Futures Contract chart. You need to use the IQ Feed back adjusted symbol. The symbol is: @NQ#C And the chart starts at: 2013-06-21 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-07 03:30:27
[2014-10-07 03:30:36] |
The prior post has been updated.
