Date/Time: Thu, 19 Nov 2026 11:17:23 +0000
Question about Numeric Information Table
View Count: 631
[2024-12-08 23:06:31]
awakef - Posts: 72
Hi I have made a custom numeric information table for my needs but my question is can I have more that 2 variables for background coloring that are not value percent with different ranges colors.
For example I want to have one background color if the value is lower than 10, one background color if the value is higher that 35, and also a background color for a value between 10 and 35.
Thanks,
[2024-12-09 15:19:53]
There is no support for what you are wanting to do.
You can either color all the backgrounds the same (assuming you implemented the "Text Background Color" option) or use the "Color Background Based on Volume Percentage". The "Color Background Based on Volume Percentage" only works the one way, and only colors based on percentage of the range of the data.
Just so you are aware, we implemented a "Numeric Information Reference" study a few weeks ago that allows you to reference 10 other studies to show in the table. Refer to the following:
[2024-12-09 15:49:50]
awakef - Posts: 72
Thanks didn't know you made the code into proper study 💪
[2024-12-09 19:13:59]
You should be able to control the numeric information table Subgraph Text color at each chart bar, with the data color array:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[]
Date Time Of Last Edit: 2024-12-09 19:14:32
