Date/Time: Thu, 19 Nov 2026 11:17:25 +0000
[Locked] - Volume By Price Bug
View Count: 518
| [2024-12-08 17:41:45] |
| TradingInDemand - Posts: 29 |
Hello, I’ve encountered a bug with the Volume By Price study when duplicating or adding a saved profile. If the profile is saved with the Volume Graph Period Type set to One Period and Right Align Volume Bars enabled, the following issues occur: The Right Align Volume Bars setting cannot be changed from "Yes" to "No." Similarly, the Align to Far Right setting cannot be toggled off and remains set to "Yes." The Period Type cannot be switched from One Period to Multiple Profiles. These issues persist even after duplicating or reusing the saved profile. |
| [2024-12-09 17:09:45] |
| John - SC Support - Posts: 48583 |
You have the Input for "Set as Independent Volume Profile for TPO Chart" set to "Yes". This is causing the issues you are seeing. Set that Input to "No" and then re-save the study collection. Refer to the following: Volume By Price Study: Set as Independent Volume Profile for TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
