Date/Time: Thu, 19 Nov 2026 11:17:01 +0000
Supported European Brokers
View Count: 1155
[2024-12-08 16:11:42]
Mrtest - Posts: 1
What brokers are currently supported in Europe? I came across an old thread from 2022 mentioning that WHSelfinvest was the only supported broker at the time, but I assume the list has been updated since then. If you have information on brokers that use Teton, CQG, or Rithmic, I’d greatly appreciate it as well!
[2024-12-09 16:29:58]
We do not have specific information on where brokers are located, or where they offer support.
Sierra Chart works with Interactive Brokers and brokers that use CQG, Rithmic, or Teton for their order routing. There are some caveats with CQG, such as Ninja Trader, so you may need to check a bit further with a broker about their specific support for Sierra Chart if they use CQG for their order routing.
