Date/Time: Thu, 19 Nov 2026 11:16:56 +0000
hot keys in drawing
View Count: 685
| [2024-12-08 07:56:27] |
| UserAlexandros - Posts: 6 |
Hello, How do I change the shortcut keys in drawing on the Chart? For example Crosshair, Extending Rectangles, Arrow, etc? |
| [2024-12-08 18:28:23] |
| Sierra_Chart Engineering - Posts: 25441 |
Refer to: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
