Date/Time: Thu, 19 Nov 2026 11:17:17 +0000
v2719 - shouldn't adding GetPrice() to s_TimeAndSales be a breaking change
View Count: 560
| [2024-12-07 17:56:29] |
| User719512 - Posts: 543 |
Hi Sierra Chart Engineering, v2719 - shouldn't adding GetPrice() to s_TimeAndSales be a breaking change and necessitate an update to #define SC_DLL_VERSION in sierrachart.h? |
| [2024-12-07 19:42:27] |
| Sierra_Chart Engineering - Posts: 25441 |
This is definitively not a breaking change at all. This has no impact at all upon any existing custom studies. Apparently you do not understand data structures. There is not a need for any update with the version number in custom studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-07 19:42:51
| [2024-12-07 20:42:02] |
After further review, I do see that this does not break the ABI (Application Binary Interface) and runtime interoperability. Thank you for your prompt, respectful and informative response. |
