Date/Time: Thu, 19 Nov 2026 11:17:23 +0000
[User Discussion] - Changing the symbol on multiple charts at the same time
View Count: 849
[2024-12-06 18:05:10]
luveglio - Posts: 2
Another question in a CHARTBOOK I inserted more charts, how can I change the symbol at the same time on all the other charts so as not to change them manually one by one?
Grazie ora ho risolto,
una'altra domanda in un CHARTBOOK ho inserito più chart, come posso cambiare il simbolo in contemporanea su tutti gli altri chart per non cambiarli manualmente ad uno ad uno?
grazie
[2024-12-06 18:12:02]
You would first need to setup the linking between the charts for the symbol. Then when you change the symbol for one chart, it will update to all the other charts that are linked. Refer to the following:
Chart Settings: Linking
