Date/Time: Thu, 19 Nov 2026 11:17:26 +0000
Some symbols not loading correctly from control bar watch list
View Count: 459
[2024-12-06 15:47:49]
sean3000 - Posts: 65
Today I added SOUN-NQTV and UBER-NQTV to my chart's control bar watch list.
When I select SOUN-NQTV from the drop down MARA-NQTV is loaded. When I select UBER-NQTV, DJT-NQTV is loaded.
I've seen this happen before with other symbols.
This issue does not occur when loading via the quote board.
Private File
[2024-12-06 17:43:21]
We are not able to reproduce this with the Symbol List you provided. But we do want to point out that you already have DJT-NQTV and MARA-NQTV further up in the list, so you do not need them towards the bottom. What we do see happen is that since the symbol is already in the list, it is not shown again in the Watch List.
Our recommendation at this point is to remove any duplicates and then import the file again for the watch list and see if that resolves the issue.
[2024-12-06 18:50:56]
Thank you, removing the duplicates resolved the issue.
