Date/Time: Thu, 19 Nov 2026 11:17:27 +0000
$PLTR_MBO missing historical Daily Chart data beyond past 6 days
View Count: 441
| [2024-12-05 14:22:41] |
| User763335 - Posts: 133 |
I see this issue only with this ticker. If I switch the same chart to Intraday Daily chart, data loads fine. Deleting & Redownload of data, doesnt help. Had this issue yesterday too. PLTR-NQTV's historical data loads fine too, just the _MBO variant has issues for this symbol only. pls advise. Thanks! |
| [2024-12-06 03:39:57] |
| Sierra_Chart Engineering - Posts: 25441 |
We are working on this now. This relates to this symbol moving from NYSE to NASDAQ. The existing data has to be moved over, to a different folder.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-06 03:40:10
