Date/Time: Thu, 19 Nov 2026 11:17:27 +0000
Mouse Scrool Wheel doesn't scroll chart up and down on some charts
View Count: 1228
| [2024-12-05 13:55:24] |
| TopGunTrader - Posts: 313 |
Hi, I'm having a bizarre problem on some charts my mouse scroll wheel doesn't move charts up and down like on all others. I've compared every setting for that chart vs ones that work and can't find any setting different. How can I fix this or is there no fix and I have to recreate the broken charts from scratch? Thanks spent so much time trying to fix this myself but unable to. |
| [2024-12-05 15:55:36] |
| John - SC Support - Posts: 48583 |
What is "Global Settings >> General Settings >> GUI >> Scroll Wheel" set to?
| [2024-12-05 20:23:13] |
Scroll Wheel Scrolls Vertical Scale. With 'Shift' Changes Spacing.
| [2024-12-05 20:28:47] |
This is a Global Setting, so it will apply to all charts. But, there are two chart settings that will affect this working, and will affect the ability to move the chart at all. 1) The chart is in "logarithmic" mode. 2) The chart scale is locked by having "Interactive Mode: Locked" selected. Let us know if the above does not solve your problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-05 20:50:22] |
OMG yes thank you not sure how I have that selected on some and not others but I often duplicate chart so it just got moved to multiple other charts. Thank you this was driving me nuts but didn't want to resetup those charts.
| [2024-12-05 20:50:42] |
I had Interactive Mode: Locked on.
