Date/Time: Thu, 19 Nov 2026 11:16:56 +0000
Current traded total volume issue
View Count: 1165
[2024-12-04 18:32:05]
User928353 - Posts: 13
i have CFD SPX500 chart (i know you don't provide market data for it) but when i turn on chart DOM column and add current traded volume and cumulative last size i am not seeing the COLOR change trades being recorded on the total volume i have attached three screen short comparing it with a emin sp 500 chart please have a look and advise.
chart size is 1 price change for spx500
Thank you
imageCapture 1.PNG / V - Attached On 2024-12-04 18:29:27 UTC - Size: 295.47 KB - 294 views
imagenot capture 1.PNG / V - Attached On 2024-12-04 18:29:43 UTC - Size: 312.81 KB - 263 views
imageno cap3.PNG / V - Attached On 2024-12-04 18:29:56 UTC - Size: 316.85 KB - 202 views
[2024-12-04 18:57:51]
We need more information on the exact setup you have, in particular the column that is displayed and what you are displaying in it - how are your Trade DOM settings set in relation to what is displayed.
Also, any particular color settings related to the above and how you have them set.
And then, we can not tell from the images what you are trying to state. Please give us more information on exactly what is occurring that is not as you are expecting it.
[2024-12-04 21:01:04]
In trading DOM on chart there is a option Current traded total volume, in that option for all other charts and symbol when a new trade happen it shows a color number on the volume that has been added like for the left chart in the image but for that option on SPX500 no number with color added for most of the trades but for some trades it does shows that colored number is added my question is why not for all trades and is that a problem with trading symbol as i have tried it in mutiple new charts and time frame all have the same problem i have added new images with some comments hope it helps
i have tried to open a new chart with that particular symbol and the problem is the same and for the DOM i have not made any particular changes to the setting of the DOM or any color setting,
I duplicated the emin sp 500 charts which is showing the color for that symbol and then changed the symbol to SPX500  and no number is there so i don't think I have made any particular change that has made the disappearance of the colored number
Thank You
imageCapture 1.1.png / V - Attached On 2024-12-04 20:59:48 UTC - Size: 315.02 KB - 240 views
imagenot capture 1.1.png / V - Attached On 2024-12-04 21:00:03 UTC - Size: 290.34 KB - 294 views
imageno cap3.3.png / V - Attached On 2024-12-04 21:00:18 UTC - Size: 300.86 KB - 280 views
[2024-12-04 22:22:08]
What is the column on the far right?
What are the following options set to?
- Trade >> Chart DOM Settings >> Display Cumulative Last Size in Current Traded Total Volume
- Trade >> Chart DOM Settings >> Reset Cumulative Last Size on Bid/Ask Change
- Graphics Settings (either global or chart, depending on which you are using) >> Colors and Widths >> Cumulative Last Size Background Bid Trade >> Color
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Background Ask Trade >> Color
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Bid Trade Same Price and Side Background Color >> Color and Enable
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Ask Trade Same Price and Side Background Color >> Color and Enable
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Bid Trade Same Price and Side Text Color >> Color and Enable
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Ask Trade Same Price and Side Text Color >> Color and Enable
[2024-12-04 23:30:18]
What is the column on the far right?- it is the cumulative last size option in DOM
- Trade >> Chart DOM Settings >> Display Cumulative Last Size in Current Traded Total Volume- YES
- Trade >> Chart DOM Settings >> Reset Cumulative Last Size on Bid/Ask Change- YES
I USE GLOBAL GRAPHICS SETTING AND THIS IS A NEW CHART BOOOK WHERE I HAVE MADE ONLY FEW CHAMGES
- Graphics Settings (either global or chart, depending on which you are using) >> Colors and Widths >> Cumulative Last Size Background Bid Trade >> Color - RED
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Background Ask Trade >> Color- GREEN
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Bid Trade Same Price and Side Background Color >> Color and Enable -WHITE AND ENBLE IS NOT CHECKED
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Ask Trade Same Price and Side Background Color >> Color and Enable- WHITE AND ENABLED IS NOT CHECKED
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Bid Trade Same Price and Side Text Color >> Color and Enable- BLACK AND ENABLE IS NOT CHECKED
- Graphics Settings >> Colors and Widths >> Cumulative Last Size Ask Trade Same Price and Side Text Color >> Color and Enable- BLACK AND ENABLED IS NOT CHECKED
[2024-12-06 09:24:44]
Any updates on this guys.
Thank You
[2024-12-06 15:01:10]
We see what is happening, which is the Current Traded Total Volume is only showing at the increments of 0.1 in the price whereas the Cumulative Total Volume is showing in increments of 0.01. So you only get the coloring in the Current Traded Total Volume when the prices happen to match up.
So we are looking into why this is occurring with SPX500.
[2024-12-06 19:15:39]
This is a CFD. Whatever behavior you are seeing is just how it is. It is not something we can allocate time to.
Do not use this symbol, and instead use SPX_CGI
Date Time Of Last Edit: 2024-12-06 19:16:20
