Date/Time: Thu, 19 Nov 2026 11:17:24 +0000
version 2716. issues continue
View Count: 598
[2024-12-04 17:41:00]
User936594 - Posts: 6
Just installed 2716 this morning. seemed fine at first. now seeing increasing lag as the day goes on, order entry lag as well as exiting trades.
windows task manager indicates high resource usage. at the moment it's basically unusable.
I've increased chart update intervals on all charts as well as removed any unnecessary indicators and studies.
Thank you
Steve
[2024-12-04 20:02:19]
C_Money - Posts: 90
Just curious, are you using any spreadsheet systems or do you have the indicator on any of your charts called "Chart Recalculation - Periodic" ? I've just been messing around trying to narrow down what's causing my issues. The chart recalculation was one cause..
[2024-12-04 21:18:47]
I'm not using a spreadsheet, and no chart recalculation.
Just the basic indicators and studies. I try to keep it simple and light on resources.
[2024-12-04 21:35:33]
User677437 - Posts: 102
How much ram does it say you are using ?
What studies market depth ? Numbered bars ? Lots of drawing tools or line extensions.
[2024-12-04 21:51:04]
C_Money - Posts: 90
I'm using primarily alot of study/price overlays, my 2 main charts have 30 indicators each, just overlays of information. 3 spreadsheets produce my signals, i got about 40 columns on each one in use.. all of it just to time all my lower time frame signals with higher time frames. my lowest time frame is 300 volume per bar. basically a 5-10 second chart or so when theres good volatility.
Ram wouldn't be the issue. Its gonna be primarily CPU, of which I'm running a Core i9 9900k. Its about 4 years old but its an 8 core processor. And to take load off the CPU I'm using OpenGL to help move the chart graphics to the GPU.
