Date/Time: Thu, 19 Nov 2026 11:17:26 +0000
Random boxes appearing on Numbers Bar Chart
View Count: 642
[2024-12-04 09:18:29]
User526268 - Posts: 14
Morning
I have a 5 min ES chart using a Numbers Bar study. It has been working fine.
This morning on start up, random boxes appear over the top of the numbers bar columns, as shown in the attached file.
I have tried "hiding" all of the studies on the chart, but they do not disappear.
Any help would be appreciated.
Regards
Julian
imageScreenshot 2024-12-04 091659.png / V - Attached On 2024-12-04 09:17:17 UTC - Size: 189.34 KB - 175 views
[2024-12-04 18:10:14]
We do not know what that could be. Since you have tried hiding the studies and that did not work, the next thing to do is to duplicate the chart, and if you still have that same issue in the duplicate, then start deleting studies completely and see which one causes that to go away when deleted.
[2024-12-04 18:33:33]
Thanks John
I did as you suggested. When I removed the Numbers Bar study, it revealed that the chart was displaying full candlesticks, as shown in the attached picture.
However, rather strangely you will see that some of those candlesticks are not displaying properly, as in there are 2 different colours on the same candle.
This is also happening on a different chart, same symbol. Also attached for you to see.
I have checked on a different symbol, and the problem does not appear there.
Cheers
imageScreenshot 2024-12-04 183218.png / V - Attached On 2024-12-04 18:33:22 UTC - Size: 42.84 KB - 170 views
imageScreenshot 2024-12-04 183152.png / V - Attached On 2024-12-04 18:33:28 UTC - Size: 123.88 KB - 172 views
[2024-12-04 19:00:00]
From the images, this would appear to be a Study/Price Overlay that is in the main chart region.
Have you deleted every study from the chart and you still have the bars showing like that?
