Date/Time: Thu, 19 Nov 2026 11:17:26 +0000
Cannot connect Apex/Rithmic to Sierra Chart.
View Count: 839
[2024-12-04 08:28:59]
trader2017 - Posts: 118
I noticed that others had the same problem. The AMP/Teton connection is working.
[2024-12-04 08:39:08]
User303857 - Posts: 201
Yes, updated to the newest version twice now....
Both Amp/Teton not working and Rithmic Apex not working.
Rolled back the update and same problems.
At some point hoping to manage the position that is on....
Date Time Of Last Edit: 2024-12-04 08:41:29
[2024-12-04 09:01:59]
User303857, this happened several months ago, and it was something that Rithmic had to fix. If you have trades initiated in Sierra Chart to Apex you’re probably aware that you can close them directly from the Rtrader app which is what I had to do since I couldn’t close them or manage them through Sierra.
[2024-12-04 10:08:31]
Sitting Bull - Posts: 13
Same for me, cannot connect to S5/TETON, also rithmic not working
[2024-12-04 14:44:57]
Are you still having an issue connecting to Rithmic?
[2024-12-04 14:59:19]
Ok for me with Rithmic connection. Thanks
[2024-12-04 21:33:38]
Every thing seems to be working again this morning.
Running Version 2716
Not sure if I should try updating again?? To the most current verson.
