Date/Time: Thu, 19 Nov 2026 11:17:02 +0000
[Programming Help] - Moving 'ALL' Stop Orders Tick Up / Tick Down Command!
View Count: 725
| [2024-12-02 21:39:08] |
| J DIDDY - Posts: 156 |
Hi Support, Is there a way or will you be introducing soon a way to move 'ALL' stop orders with the key command 'Stop Orders Tick Up / Tick Down'. I scale in alot (always with attached stop loss orders) and always try to get up max lots (100 micros) with different trail distances, and I wanna be able to move/manage them all at the same time, as you can imagine tryna move 100 trailing orders one by one is craziness! That would be very helpful! Thanks Date Time Of Last Edit: 2024-12-03 14:04:21
| [2024-12-04 19:03:01] |
| ForgivingComputers.com - Posts: 1253 |
If you are scaling in, have you checked Trade Window>>Menu>>Order>>Support Scale In? This will add to your parent order, as well as your stop and target orders, so you can move one stop for all orders. However, if you do want separate stops for all the orders, then a custom study could do that. Date Time Of Last Edit: 2024-12-04 19:04:59
| [2024-12-04 19:54:56] |
HI ForgivingComputers I need separate stops. Like I said they all have different trails. I'm not keen on the Support Scale in/Out function as I use Theoretical Ave Price. Thanks anyway Date Time Of Last Edit: 2024-12-07 10:11:51
