Date/Time: Thu, 19 Nov 2026 11:17:19 +0000
bracket order
View Count: 527
| [2024-12-02 20:20:52] |
| User756716 - Posts: 32 |
Before I installed the latest upgrade I was able to see my p/l on the bracket order target or stop loss. I would point my cursor on the target or SL order and it would should me how many points it would be worth. I can no longer see that option after the upgrade. I also uninstalled the current and installed the previous version and I get the same results.
| [2024-12-02 20:25:34] |
| John - SC Support - Posts: 48583 |
Set the following options to "Yes": Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Global Trade Settings Windows: Attached Order P/L Always (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
