Date/Time: Thu, 19 Nov 2026 11:17:27 +0000
windows vs sierrachart timers for low chart update interval
View Count: 707
| [2024-12-01 00:13:08] |
| User753428 - Posts: 185 |
there are many of us who must use a low chart update interval (10-20ms) for our trading. all other factors considered equal (internet speed, cpu, gpu, etc.), is windows or sierrachart timer better for charts set at 10-20ms chart update interval? i'm specifically just talking about chart windows. |
| [2024-12-01 01:05:17] |
| Sierra_Chart Engineering - Posts: 25441 |
Sierra Chart timers are always going to be better than Windows, but with the latest change in version 2712 (We will release notes about that later today), the behavior with Sierra Chart timers versus Windows-based timers should be the same. And the added benefit is with Sierra Chart timers there is lower resource usage. Anyway, definite decision has been made that we are not going to be using Windows timers any longer. There is no reason to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-01 01:05:42
