Date/Time: Thu, 19 Nov 2026 11:17:17 +0000
5M count down timer above bar
View Count: 476
| [2024-11-29 16:07:07] |
| WiddyTrading - Posts: 11 |
Hello! I am trying to have the 5M countdown time display above the 5M bar. The Countdown study is working just fine. However, when I reference SG.1 from the countdown timer into the Display Above/Below Bar study it is only showing in seconds. Any idea what may be causing this? |
| [2024-11-29 17:55:52] |
| Sierra_Chart Engineering - Posts: 25441 |
There is not support for what you want to do.
| [2024-11-29 18:31:31] |
Bummer, thanks.
