Date/Time: Thu, 19 Nov 2026 11:17:13 +0000
[Programming Help] - Convert 32bit dll indicator to 64bit
View Count: 623
[2024-11-29 13:17:52]
1HpreSierra - Posts: 2
hello there, the SC board have some older indicator available in 32bit version only. Obviously, not usable for the current version.
Is there a way to re-code the attached fil, made by tobi for 64bit version?
attached source cpp file
attachmentswing-points.cpp - Attached On 2024-11-29 13:16:03 UTC - Size: 2.2 KB - 194 views
[2024-11-29 13:56:01]
A CPP file, is not associated with 32 or 64-bit.
If there is any compiler errors we can resolve those. We will look at this a little later.
[2024-11-29 14:00:57]
Thanks,
I wanted to attach this *.dll version , but if c++ makes it faster, only better...
Private File
[2024-11-29 15:30:04]
seandunaway - Posts: 399
i haven't tested it but it compiled successfully against modern sierrachart without warning
attachmentswing-points_64.dll - Attached On 2024-11-29 15:29:49 UTC - Size: 93 KB - 221 views
attachmentswing-points_arm64.dll - Attached On 2024-11-29 15:29:52 UTC - Size: 81.5 KB - 306 views
[2024-11-29 20:31:32]
If you want to build that CPP file yourself, refer to:
How to Build an Advanced Custom Study from Source Code
