Date/Time: Thu, 19 Nov 2026 11:17:21 +0000
recalculation infinite loop if chart contains 1 bar
View Count: 1131
| [2024-11-28 20:07:43] |
| seandunaway - Posts: 399 |
if the chart contains only 1 bar there is a silent recalculation infinite loop, causing ui glitching and preventing any custom study from submitting orders e.g. a chart with 1 days to load and 1-0-0-0 bar period have a minimum of 2 bars to resolve documenting incase anyone else runs into this in the future; it's a proper headache to diagnose keywords: sc.IsFullRecalculation, SCT_SKIPPED_FULL_RECALC, Order entry skipped because full recalculation Date Time Of Last Edit: 2024-11-28 20:54:50
| [2024-11-28 22:24:01] |
| Sierra_Chart Engineering - Posts: 25441 |
This is not making any sense. There is no infinite loop. There could not be any user interface problem either with this. There must be something, your custom study is doing that is causing a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-28 22:24:21
| [2024-11-28 23:38:59] |
please check that an intraday chart with 1 bar (e.g. 1 days loaded and 1 day bar period) is in constant recalculation #include <sierrachart.h>
SCDLLName("recalc") SCSFExport scsf_recalc(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.AllowOnlyOneTradePerBar = 0; sc.GraphName = "recalc"; sc.GraphRegion = 0; sc.UpdateAlways = 1; return; } if (sc.IsFullRecalculation) return; // ! if (!sc.GetCustomStudyControlBarButtonEnableState(2)) return; s_SCNewOrder order; order.OrderQuantity = 1; order.OrderType = SCT_ORDERTYPE_MARKET; int result = sc.BuyEntry(order); if (result < 0) sc.AddMessageToTradeServiceLog(sc.GetTradingErrorTextMessage(result), 1, 1); sc.SetCustomStudyControlBarButtonEnable(2, 0); } animated gif attached Date Time Of Last Edit: 2024-11-29 00:39:40
| [2024-11-28 23:57:15] |
adding more than one bar resolves animated gif attached |
| [2024-11-29 01:28:23] |
There is not a constant recalculation. This is not possible. It is just that the Full Recalculation flag is always true every time the study is calculated according to the standard rules.
