Date/Time: Thu, 19 Nov 2026 11:16:56 +0000
Police étiquettes
View Count: 855
| [2024-11-27 14:24:43] |
| User914407 - Posts: 65 |
Bonjour, Comment changer la police des étiquettes sur les lignes matérialisant les trades ? |
Attachment Deleted. Private File |
| [2024-11-27 17:13:52] |
| John - SC Support - Posts: 48583 |
From Google Translate: Hello,
How to change the font of the labels on the lines materializing the trades? What is in your image are the "Order Fills". To controls to change the font for the Order Fills is located on the "Graphics Settings" window under the Fonts tab. Select the "Chart Order Fills" item and modify the font for it. Refer to the following: Graphics Settings: Chart Order Fills For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-28 15:36:40] |
Et comment modifier les autres infos présentes sur cette étiquette (gain en € plutot qu'en Points par exemple ?
| [2024-11-29 21:16:07] |
| Sierra_Chart Engineering - Posts: 25441 |
Refer to this Chart Setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
