Date/Time: Thu, 19 Nov 2026 11:16:59 +0000
Change the Symbol Colors in the Control Bar
View Count: 506
| [2024-11-27 12:38:05] |
| User871209 - Posts: 99 |
Hello, Could someone please guide me on how to change the color of the symbols in the control bar (not the text, but the icons/symbols)? Thank you! Attached picture. |
Attachment Deleted. |
| [2024-11-27 16:56:24] |
| John - SC Support - Posts: 48583 |
You can not change the colors themselves. You just have to set an image to be used for the button that is colored the way you want it. Refer to step #10 at the following: Control Bar: Control Bar Button Properties For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
