Date/Time: Thu, 19 Nov 2026 11:17:13 +0000
Chart display is cut off
View Count: 533
| [2024-11-27 03:52:51] |
| pjk0225 - Posts: 44 |
Screenshot: https://www.sierrachart.com/image.php?Image=173267914786.png Right chart is working correctly. Left chart displays drawings but not bars on the right side. Things I've tried: - removing all studies - closing and reopening chartbook - turning off and on 'OpenGL' - restarting the program - pressing 'end' - resetting scales - zooming in and out - panning left and right - changing tickers - changing data load dates - changing number of forward columns It was working fine until I made an edit to one of the studies and started moving the chart around. |
| [2024-11-27 15:54:12] |
| John - SC Support - Posts: 48583 |
Check the "Chart >> Lock Fill Space" option. Refer to the following: Chart Menu: Lock Fill Space (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
