Date/Time: Thu, 19 Nov 2026 11:17:06 +0000
REPLAY CHART
View Count: 418
[2024-11-26 23:51:59]
User236502 - Posts: 1
MY REPLAY CHART FEATURES IS NOT WORKING ANYMORE
[2024-11-27 14:31:43]
What exactly is the problem?
If the control window is not showing when you select it, then select "Chart >> Replay >> Reset Replay Control Panel Window". Refer to the following:
Chart Menu: Reset Replay Control Panel Window (Chart >> Replay Chart menu)
