Date/Time: Thu, 19 Nov 2026 11:17:14 +0000
Question on Chart Trade.
View Count: 435
| [2024-11-26 19:06:54] |
| G369 - Posts: 27 |
Hi, I have MNQ charbook with multiple charts open of the same MNQ with different indicators with different bar styles. When I place a trade on the anchor chart of the chartbook, I cannot see the remaining charts in the same workbook as the trade lines are covering all the charts. I want to see trade info only on the anchor charts so that I can view the movement of indicators on other charts of the same symbol and same chartbook. How do i do that? Is there a way to hide the "Order Fills" on other charts of the same symbol? regards |
| [2024-11-26 19:09:55] |
| John - SC Support - Posts: 48583 |
In order to not see the Position Line, Order Lines, and/or Order Fills on a chart, that chart needs to not have the option for "Chart Trade Mode On" enabled. Refer to the following: Trade Menu: Chart Trade Mode On (Trade menu) If you want to have certain elements from the DOM displayed in the above case, then enable the option for "Trade >> Show Market Data Columns". Refer to the following: Trade Menu: Show Market Data Columns (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
