Date/Time: Thu, 19 Nov 2026 11:17:07 +0000
Nasdaq index feed
View Count: 2029
| [2024-11-26 14:45:15] |
| Jimmyy - Posts: 358 |
Hello, This is the third time I am requesting to be able to relist the nasdaq index feed. Just for this one ticker I have to also pay for tradingviews subscription, which i dont mind but not just that, their platform is complete garbage, despite paying for the platform and the feed, the feed is still slow, which i absolutely hate. They currently have a sale going on - so, if there is any possibility of nasdaq index feed being relisted on SC in the near future or even after some months, I would really appreciate that and would be willing to wait. I really dont want to purchase their subscription and have SC as my sole platform for everything. Thank you. |
| [2024-11-28 03:03:22] |
| User278450 - Posts: 8 |
Which symbol are you looking for?
| [2024-11-28 04:50:58] |
the nasdaq index ticker that comes from nasdaq exchange. It was available before but was delisted when SC made CBOE available.
| [2024-11-29 21:57:20] |
| Sierra_Chart Engineering - Posts: 25441 |
There are no plans to be adding cash indices from NASDAQ anytime soon.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-29 21:57:53
| [2024-11-30 08:51:39] |
Do you guys know if rithmic / CQG would be able to provide me with nasdaq index data?
Date Time Of Last Edit: 2024-11-30 08:56:15
| [2024-11-30 13:15:18] |
| User512353 - Posts: 198 |
I think there should be a poll, how many users would be interested in receiving real-time Nasdaq indexes via the SierraChart datafeed, and for which prize. Plus a decent amount of historical index data (price+volume), e.g. 10 years daily data, 1 year intraday. I would be interested too. But who knows, how many others also... Date Time Of Last Edit: 2024-11-30 14:07:54
| [2024-11-30 14:43:22] |
Yes please +1 from me
| [2024-12-02 14:35:08] |
Hi support, So I was able to confirm that CQG and Rithmic provides Nasdaq cash index data. so would i be able to receive CQG/Rithmic and Denali data in the same SC? or can I trade with CQG/Rithmic in one instance with denali data and use CQG/Rithmic on another instance to receive the nasdaq cash index data? is any of this possible ? Thank you Date Time Of Last Edit: 2024-12-02 18:03:32
| [2024-12-02 19:25:26] |
| John - SC Support - Posts: 48583 |
If you are using CQG or Rithmic for your trading service, then you can get the Denali data along with data for that index from CQG or Rithmic in a single instance of Sierra Chart. Otherwise, if you just want to get their data and are not connecting to them through the "Current Selected Service" then you would need a separate installation of Sierra Chart to connect to CQG or Rithmic in order to get that data. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-02 19:37:36] |
So just to be clear - in the same installation of SC - i would be able to connect to CQG/Rithmic and denali data right? Like I can have data being received for ES from denali and be able to trade on this (ES) ticker with CQG/Rithmic and also have nasdaq index data being received from CQG/Rithmic on another chart within this same SC. Am I correct? Date Time Of Last Edit: 2024-12-02 19:38:13
| [2024-12-02 20:18:34] |
Like I can have data being received for ES from denali and be able to trade on this (ES) ticker with CQG/Rithmic and also have nasdaq index data being received from CQG/Rithmic on another chart within this same SC. Am I correct? Yes, this is correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-03 05:24:43] |
Which one would you suggest in terms of getting data and order transmissions and with less problems?
| [2024-12-03 17:05:43] |
They both have their shortcomings, but CQG tends to have better quality with order routing and connectivity.
| [2024-12-04 08:03:43] |
Also, you said i can have both the data(cqg and denali) flowing in at the same time. I wanted to ask, that will also be the case in a sub instance of that same SC right?
| [2024-12-04 16:01:33] |
Yes, this will also be true for any sub-instances.
