Date/Time: Thu, 19 Nov 2026 11:17:17 +0000
[Programming Help] - Bar has Closed in Renko
View Count: 699
| [2024-11-26 08:15:55] |
| User921201 - Posts: 6 |
When using Renko Bars in Sierra, how can I get to know if the renko bar has closed or not? is it the same as sc.GetBarHasClosedStatus() or something else for it? Also when using Renko Bar with Wicks, is there a way to get the high and low of the bar? Or I can only get Close and Open of the renko bar?
| [2024-11-30 18:49:26] |
| ForgivingComputers.com - Posts: 1253 |
Yes.Renko Bar with Wicks, is there a way to get the high and low of the bar? Or I can only get Close and Open of the renko bar?
float High = sc.BaseData[SC_HIGH][sc.Index];
float Low = sc.BaseData[SC_LOW][sc.Index]; |
