Date/Time: Thu, 19 Nov 2026 11:17:14 +0000
Comparison at specific time of the day, indicator search
View Count: 522
| [2024-11-26 05:17:55] |
| User893396 - Posts: 40 |
Hello, I would like to compare the daily cumulative Volume (or delta, or range, or anything else...) at this particular time of the day to the average daily cumulative volume (or delta, or range, or anything else...) over last X days at the exact same time of the day. Example: it's 4pm and the daily cumulative is 500k on the NQ. At the same time of the day over the last month the daily average cumulative volume was 400k at the same time (4pm). So today, we are 100k above the average, or 20% above the average. Which studies should I use for these types of calculations? Are there some custom studies that you can recommend for this? Some key words to look for? Thanks for your help |
| [2024-11-26 15:05:28] |
| John - SC Support - Posts: 48583 |
The Relative Volume study does this. Refer to the following: Relative Volume Note the section for "Basing Relative Volume Study on Another Study for Non-Volume Comparisons" on that page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
