Date/Time: Thu, 19 Nov 2026 11:17:22 +0000
[User Discussion] - Installer
View Count: 680
[2024-11-25 23:04:38]
JJ Trading - Posts: 2
I'm a new user trying to install Sierra Chart via Crossover. Getting the error messages attached.
imageScreenshot 2024-11-25 at 5.02.04 PM.png / V - Attached On 2024-11-25 23:03:36 UTC - Size: 26.18 KB - 288 views
imageScreenshot 2024-11-25 at 5.02.36 PM.png / V - Attached On 2024-11-25 23:03:43 UTC - Size: 28.69 KB - 274 views
[2024-11-26 01:34:10]
In this case we recommend using the Sierra Chart Zip installer:
Software Download: Sierra Chart Zip Installer
[2024-11-26 02:29:45]
It still doesn't seem to be working with the Zip Installer. Screenshot attached. Let me know if I'm not using it correctly or need to adjust anything on my end.
imageScreenshot 2024-11-25 at 8.23.31 PM.png / V - Attached On 2024-11-26 02:29:01 UTC - Size: 179.26 KB - 293 views
[2024-11-26 16:02:00]
Tony - Posts: 733
I usually changed the Drive from "Y" to "C"
I would like to recommend using WINE if possible,
feels great when I have the full control.
Date Time Of Last Edit: 2024-11-26 16:50:55
[2024-11-28 22:21:36]
Regarding post #3, you will need to get a zip/unzip utility that will run on Crossover or Linux. And then you need to unzip the Sierra Chart zip file.
