Date/Time: Thu, 19 Nov 2026 11:17:14 +0000
indication de trade sur graphique manquant
View Count: 449
| [2024-11-25 22:25:28] |
| User436656 - Posts: 2 |
Bonjour Quand je prends un trade en SIM je vois le trade s'afficher sur le graphique. Quand je prends un trade en réel il ne s'affiche pas sur mon graphique pourquoi? Quelle est la manipulation a faire pour corriger ce problème ? Merci pour votre réponse |
| [2024-11-25 22:28:08] |
| John - SC Support - Posts: 48583 |
From Google Translate: Hello
When I take a trade in SIM I see the trade displayed on the chart. When I take a trade in real it does not display on my chart why? What is the manipulation to do to correct this problem? Thanks for your answer If you are referring to the order and position lines, then as long as you have not changed anything about your charts, then it should be the same whether you are in Simulation Mode or not. Are you certain that the live orders are actually going through? It sounds like they may be being rejected and not being sent to the exchange. Please check with your broker on this. If the orders are not getting to the exchange, then we would need to see your "Trade Service Log" after you try to send a trade. Please follow the instructions at the following link to get us the log: Support Board Posting Information: Providing Lines From Trade Service Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
