Date/Time: Thu, 19 Nov 2026 11:17:15 +0000
order position/association lines
View Count: 661
| [2024-11-25 20:24:51] |
| kennedpa - Posts: 16 |
Been a while, unable to find the documentation or setting for limiting the size of the offset for the position line from the right axis of the chart. Previously I know I adjusted this to get the orders to nest closer to the right axis instead of going across the entire chart. Can you direct me to the setting area for this? Thank you |
| [2024-11-25 21:53:32] |
| John - SC Support - Posts: 48583 |
Refer to the following: Chart Settings: Trade Drawing Left Align % (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
