Date/Time: Thu, 19 Nov 2026 11:17:05 +0000
Tile View Modification
View Count: 531
| [2024-11-24 22:29:24] |
| paluszkin - Posts: 10 |
Is there any possibility to make the tile window frames (the ones arrows are pointing to) any smaller, or not visible at all? They take relatively big amounts of space. Thank you https://www.sierrachart.com/image.php?Image=1732487105451.png |
| [2024-11-24 23:00:54] |
| Sierra_Chart Engineering - Posts: 25441 |
We do not understand what you are referring to. There are no arrows in that screen image. If you used the command to capture the entire Sierra Chart main window not sure why the entire window was not captured. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-24 23:01:54
| [2024-11-24 23:18:56] |
https://www.sierrachart.com/image.php?Image=1732490272917.png This is what I ment. I can't get those arrows higher, but I am refering to the frames. |
| [2024-11-25 06:25:04] |
We cannot help with this. This is not controlled by Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-25 11:18:37] |
| Tr00pz - Posts: 32 |
If you are short on screen space, you can hide title bar and scroll bar by going to Chart > Show Title Bar/Show Scroll Bar and uncheck these. If you want to still see both of them on a single chart that you have focused, you can go to Global > General Settings > GUI > Auto Hide Charts Title Bar and Scrollbar and set this to yes. This will show the title bar and scroll bar only on the chart that you have focused while hiding them on the other charts. Hope this helps. |
| [2024-11-25 16:55:05] |
That's extactly what I needed. Thank you
